Sulu_leo
Aug 18, 2019Aspirant
Orbi RBR50 router slowing internet speed when even wire connected
I have 100 mb/s internet speed and I get same speed from my modem but when I use orbi as wifi router speed usually slows down then I connect my ps4 with ethernet cable to the Orbi router but I still get no more speed then 50 mb/s and latency issues, orbi is up to date latest version and when I reset orbi it fix it self for a while then few days later same issue any one have and idea?
Sorry for the bad English:)
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option #1...
What are the wired speeds days later with a wire connected PC?
- Sulu_leoAspirant
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
My Modem Netgear C3700 and all the wireless setting are off but the modem side
The PC which conneted the netgear c3700 modem directly has 100Mbps(my Internet speed limit 100mbps)
So I didn't think i could be my modem but modem is 4 years old modem aswell- FURRYe38Guru - Experienced User
Modem Combo Units:
Couple of options,
