MD99
Dec 31, 2018Follower
ORBI RBR50 ROUTER WILL NOT CONNECT
ORBI router will not connect to the internet. And there is NO support from Netgear available. Any suggestions?
You'll have to help us out here. We know nothing about what is going on at your end.
Has it ever connected?
What are you doing that won't work?
What is the modem that is feeding your Orbi?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.There is a manual for the Orbi WiFi System somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
What have you tried? If you are within the 90-day slot for free support, then get there through MyNetgear.
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
