bitb2072
Aug 04, 2018Aspirant
Orbi RBR50 running 2.1.4.16 dropping Wifi Connection to a Blackberry running Android
I have had my Orbi for a while now and it is stable with every device in my home EXCEPT my Blackberry Keyone running Android.I do not have the connectivity issues when connected to other routers and devices. I travel a lot for work and the only router I have issues with is the Orbi on the device.
This had not always been the case either. It was previously not an issue and as stated above not an issue on other routers.
How is the Orbi configured? If other devices work ith the Orbi, the it's possible this Blackberry may have compatiblity problems with the Orbi. I would ask the Mfr of this Blackberry if they have tested this with an Orbi system and have any help and information regarding it.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- bitb2072Aspirant
I already had the channel turned to 6, 20/40 disabled and the 5.0 netowork disabled. I will try the rest of the setting changes and follow up.
- bitb2072AspirantSo, the only change I made was I disabled the Daisy chain and so far everything seems to be stable. I had already made the other suggested changes before addressing the community.
Hope it keeps working for you.
Enjoy.
- bitb2072Aspirant
Still having issues. I did a Master Reset and am going to go back and check the settings again. Not sure why the thing won't keep a connection to my Blackberry. Makes no sense at all.
I recommend contacting the Mfr of this device to see if they have any help, or information on this device. See if they have done any testing with Orbi with there devices....
