CherryBomb666
Jul 11, 2020Follower
Orbi RBR50 satellite only giving me 1/10th internet speed
I pay for ATT fiber which is 1000 mbps down. When connected to the orbi satellite with a cat 6 cable with the orbi router also connected to the modem (Arris BGW210-700)with a cat 6 cable i'm getting ...
Jul 15, 2020Guru - Experienced User
Your modem already has a built in router.
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
i recommend trying option #3 first.
You'll not see much speeds over 400-500Mpbs on AC. Depending upon designe and support of the wifi adapter or device. Wired LAN cable speeds should be near 900Mpbs at the RBR.
ATT Modems:
https://www.f0il.com/how-to-arris-bgw210-700-modem-router-with-netgear-xr500-router/
https://community.netgear.com/t5/Orbi/How-do-I-setup-bridge-mode-in-the-ARRIS-BGW210-700/m-p/1875994/highlight/true#M84982
