space_rover's avatar
space_rover
Follower
Aug 12, 2020
Orbi RBR50 slow download much faster upload
I'm currently recieving 11 mbps download, and 49.58 mbps upload, directly from the router unit via ethernet cable, and about half that via wifi. This issue has been occuring on and off for several months. I'm supposed to be getting 50 mbps through Everywhere Wireless.
I have tried updating the firmware to latest (V2.5.1.16) (both via the app and manually via the browser), rebooting numerous times, unplugging the (2) sattelites,  even factory reseting everything, with no success. I also tried adjusting the channels as well with no success.
Any ideas of how to fix this? It seems odd that download speeds are significantly less than upload speeds in my case.
  • FURRYe38's avatar
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • Mstrbig's avatar
      Mstrbig
      Master
      When you say router, do you mean Orbi router or ISP router. If Orbi router, what is it plugged in to? If you have an ISP modem, plug directly into that and tell us your speeds.
