deanandkt
Oct 13, 2018Aspirant
Orbi RBR50 Slow Wired WAN after 2.2.1.210 Upgrade
My system updated automattically this week from 2.1.4.16 to 2.2.1.210. I have ATT Fiber and would normally get 800/800 before the upgrade. After the upgrade my up/down is 30/300ish. I connected my...
- Dec 13, 2018
The Pace modem in DMZ Plus mode ended up being the issue. I posted a response twice indicating this but for some reason it never actually posted.
Oct 13, 2018Guru - Experienced User
I would try this:
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
- jarvis42Nov 21, 2018Aspirant
After having slow wired (fine when connected directly to modem at 800+mbps, connected wired to Orbi was ~100mbps) & wireless speeds recently, I tried disabling Daisy Chain as suggested (it was shown as enabled). After Orbi rebooted, speeds went back up to what I expected.
- FURRYe38Nov 21, 2018Guru - Experienced User
Crazy that Daisy Chain is effecting performance. Hope NG will fix this. Glad you got it working.
Enjoy.
- elguezioNov 21, 2018Aspirant
I just found this thread because I'm experiencing the same issue. I'm not sure when it started, though, so I hadn't realized that it might be associated with this firmware upgrade. When I connect directly to my AT&T U-Verse Gateway via ethernet I get 100mbps down and up. When I connect via ethernet or wireless through my Orbi the upload speeds stays the same but the download speed drops to 50mbps. DMZ and everything is configured correctly as described here: http://www.dslreports.com/faq/17804
This router / modem combo worked fine for months. I tried disabling Daisy Chain but that had no effect. Any other ideas? Has anyone been able to downgrade the firmware successfully? Is that safe to do with the security vulnerabilities going around?
- FURRYe38Nov 23, 2018Guru - Experienced User
How was the FW upgraded on the Orbi? Auto update? If so, Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416Set up from scratch and be sure not to enable any QoS, Traffic Meter or Access controls.
I would also try AP mode on the Orbi as well.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
