BKP153
May 17, 2020Aspirant
Orbi RBR50 system blocking Madden app
I upgraded to on Orbi system at the end of last year and everything was working great. Out of nowhere, I could no longer log into my Madden app on my iphone or ipad. It may or may not have coincided with the firmware update V2.5.1.8 but I am not sure. I thought it was the app but I contacted their tech support and they determined it was my WiFi. I can connect with no problem using cellular data but if i switch to my WiFi, I get an unknown error and the app stops loading. A few weeks ago it started working again but then stopped again a couple days ago. I am also unable to connect to my credit union's website so I assume it is the same problem? Any ideas??
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- BKP153Aspirant
I upgraded the Orbi's Firmware to version about a month ago (V2.5.1.8). My internet connection is through an RF Antenna so there is not a modem between the Orbi and the antenna.
Do you have Armor or Circle enabled on the RBR?
What is the IP address the RBR is getting from your ISP? Something like ##.##.###.### or is it a 192, 172 or 10 IP address on the Internet port?
