Patrick_2
Oct 02, 2018Tutor
Orbi RBR50 use USB connected Harddisk for TimeMachine backup OSX 10.14
I connected my time machine harddrive to the orbi satalite with USB. The harddrive is visible through smb://readyshare/USB_Storage from my OSX and i can access the data, but it's not available under ...
- Oct 14, 2018
Hi Patrick_2,
Welcome to NETGEAR Community!
The ORBI's USB port is only for printers with ReadyPrint. It's not available for external storage.
You may raise this query or suggestion to this page :
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
Blanca
Community Team
Oct 02, 2018Guru - Experienced User
I would contact Apple support for help and information regarding there product.
Patrick_2
Oct 02, 2018Tutor
Thanks for the reply. I would like to have some information if someone has successfully setup a time machine over WIFI USB with the RBR50.
- FURRYe38Oct 02, 2018Guru - Experienced User
- Patrick_2Oct 02, 2018Tutor
Thanks for the reply. I have tried these steps, but the tutorial is outdated and it did not work anymore this way.
- Blanca_OOct 14, 2018NETGEAR Employee Retired
Hi Patrick_2,
Blanca
Community Team
