Hasselblad100's avatar
Feb 28, 2021
Orbi RBR50 Vigor 130 and Sky UK
Hi
I'm having issues with stability of my Sky Hub throughput so have decided to try and go with a 3rd party modem (Vigor 130) and the RBR50 in Router mode in order to dump the Sky Hub altogether
The Vigor connects up to the DSL and it can see 55mbs up and 20 down, which is what is provided from the cabinet - looks good.
However, when I log into the Orbi and access the Internet Settings. I choose Login Required, PPPoE, let the Orbi automatically fill addresses in the other boxes. The Sky VDSL service requires some generic credentials so I can't log in without those.
Is there possibly an issue with the DCCP 61 support on the router, because the settings don't have Option 60/61 settings unless you say that a login is not required, which for Sky it is.
Any suggestions gratefully received :-)
