gooders
Dec 06, 2019Aspirant
Orbi RBR50 VLAN setup
Hi there
I'm trying to connect my Orbi RBR50 to my new FTTC NBN connection (with TPG).
I need to change my VLAN settings to do this.
But when I try to follow the instructions for this in the manual...
"Select ADVANCED > Advanced Setup > VLAN/Bridge Settings"
There's just one problem...there's no VLAN/Bridge Settings tab there!
I've looked all over for it, but can't seem to find it.
Any ideas please?
Thanks
VLAN / Bridge is the very bottom menu item. On my PC, I have to scroll down to find it.
What browser are you using? Try a different browser?
gooders wrote:Hi there
Any ideas please?
Thanks
- goodersAspirant
Was using safari, but changing to chrome the option is now there!
Thanks v much for your help!
