hamiltdl's avatar
hamiltdl
ORBI RBR50 w/ 1 Sat Constant Connection Lost
Model: ORBI RBR50 w/ 1 sat
Firmware: V2.0.0.74
OS: Win10, Android
Mode: Router
Seems to be the same old story every where in this community. My Orbi constantly loses connection.  This interfers with all connected devices (constant freezes, lost internet of things connections and constant resets)  I have the most current software, yet I'm still consistently losing connection to the internet and my devices. I even have : (Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices) selected and this does nothing for reliability! Very frustated and ready to abandon NETGEAR all together.... Please help!!!
  • Yes,I also have done many factory resets and nothing has helped.  I've also had my cable company's line checked once at their expense and once at my expense (more money wasted).  There are no issue on their  side so, after having experiences these constant drops repeatedly for about a year (got my orbi when it was released), if I can't resolve it this time then I'll have to ditch NETGEAR FOREVER and fork out more money for a better, more reliable product.  Researching new products now to find one that works...a better mesh router!
  • I solved my issue by "upgrading" to the 1.11.0.20 firmware
    I don't know about any features the new versions have that I would use so I'm sticking with this firmware for the forseeable future
    https://kb.netgear.com/000038846/RBR50-RBS50-Firmware-Version-1-11-0-20
    I updated the router, then the satellite, and had to sync the satellite again after
    Also, the satellite wasn't letting me log into it, saying I was inputting the wrong password, so I had to factory reset the satellite and sync it again before updating it
    I had to disable automatic updating so it wouldn't go back to 2.whatever
    https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/m-p/1323973#M10304
    Note: I also had to set orbi_auto_upg=0
    • hamiltdl's avatar
      hamiltdl
      Thanks...I'll give it a try after the holiday!!!  Cheers!
  • Same here, factory reset did nothing for me, sure is fun to get kicked out of games because my >$300 Wi-Fi system isn't stable
    • hamiltdl's avatar
      hamiltdl
