audrajhust
Oct 12, 2018Follower
Orbi RBR50 wifi connection not working and sending 404 - not found message
We have an Orbi RBR50 that I purchased and installed to create a stronger wifi network for streaming and multiple device usage. The only device it will let connect to it properly is my MAC and even t...
Jan 28, 2019Guru - Experienced User
lepack
Mar 11, 2019Aspirant
Went through the same disappointment with my Orbi. It just started throwing 404s and not allowing connection to many devices. Factory reset made it come back to life but frustrating to see that this issue hasn’t been resolved/addressed.
- FURRYe38Mar 12, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?There is newer FW available.
lepack wrote:
Went through the same disappointment with my Orbi. It just started throwing 404s and not allowing connection to many devices. Factory reset made it come back to life but frustrating to see that this issue hasn’t been resolved/addressed.- lepackMar 12, 2019AspirantCurrent FW is 2.2.1.210. Is this the latest? ISP router is a Cisco DCP3825. Thanks!
- FURRYe38Mar 13, 2019Guru - Experienced User
What model Orbi do you have?
50 series new FW:
20/40 series new FW:
Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
