deltabravoh
Aug 03, 2017Aspirant
Orbi RBR50 with two RBS50 disconnects
I've updated to latest firmware and did a factory reset. Do I need to switch to AP mode as well? If this doesn't work I'm returning it. the last two months of disconnects, at the worst time too, are enough
- DarrenMSr. NETGEAR Moderator
Hello Deltabravoh
can you give some more detail on the disconnects you are having are they all the time or at certain times? only on the satellites or router or both?
DarrenM
- deltabravohAspirant
It's appears to be at random times.
I would make sure MuMimo and beamforming are enabled under the Advanced setup-Wireless settings.
DarrenM
