golfhacker57
Dec 07, 2017Aspirant
Orbi RBR50
I recently switched ISP from ATT to Cox and also got a Linksys CM3024 modem. Prior to switching to Cox and getting the new modem, I was able to view my Q-See QTH85 cameras outside of my LAN. I no longer can. I have forwarded ports 85 and 6036 on my Orbi but when I check the ports, it reports that it is still closed. The DVR is assigned a static IP address. Any help will be appreciated.
- DarrenMSr. NETGEAR Moderator
Did you bridge the new modem to be only a modem?
DarrenM
- golfhacker57Aspirant
The new modem is strictly a modem and not a router/wifi. It is a Linksys CM3024.
They could be ports blocked by your ISP have you checked with COX?
DarrenM
