Moneypit's avatar
Moneypit
Orbi Rbr50
Can anyone help me with this issue
I currently have an Orbi rbr50 with one satellite which works well but when I recently installed a ring floodlight security camera to the network, I already had a ring pro doorbell installed which also function well until I installed the floodlight, the live view on the ring devices would not connect
The issue seems to that live view when using an iPhone which is connected to the Orbi will not connect .. However when out side the Orbi network I can access live view . It’s as if the Orbi cannot handle the band width of the downstream from the cam and the upstream to the app of the phone.. which seems bizzare as I can FaceTime or Skype across the Orbi network
All other Ring functions work either when inside or outside the Orbi network I have tried the 20/40 coexistence enablement and switch channels on 2,4ghz none made any difference . I have good rssi to both devices and the satellite is hard wired . Have contacted Ring who have no idea why it doesn’t work when on Orbi and since it worked in the past with one device and works across networks it must be an Orbi issue .. Does anybody here have a solution to this problem or experience the same ??
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    What happens if you temporarily disable the 5Ghz SSID broadcast on the RBR and try the iphone again? Under Advanced Tab/Advanced Settings/Wireless Settings
    • Moneypit's avatar
      Moneypit
      FM is V2.3.1.60
      Router is a Virgine Media Hub 3.0      380Mbt/40mbt    Im in the UK
      Orbi ia operating in Router mode
      Home is 4000SqFt build with brick and cblock internal wallls
      Satellite is hardwired and is ca 50 ft away from router.
      Using Channel 1 but have swapped from 6 and 11.
      Yes some neighbours around hence swapping channel
      so I did disable the 20/40 MHz Coexistence
      Disabled chaining
      Enabled Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
      Enable MU-MIMO
      and the all seems to be working, so will have to see if it was the reboot of the router or whether it was the chaining, as i guess that was the issue I I had the satellite connected wirelessly but connectivity was up and down so hard wired it, i didnt dissable the chaining.
      Thanks for the reply and the suggestions, I will monitor and slowly make the remaining changes to see if this makes any difference.
      thanks again
