lfd346's avatar
lfd346
Orbi RBR50
My Orbi keeps loosing connection. I thought this was fixed after the last firmware update but it has started again. Any help with this would be appreciated.
  • michaelkenward's avatar
    michaelkenward
    Losing connection in what way?  Wifi? Wired? Internet?
    It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
  • FURRYe38's avatar
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    Has a factory reset and setup from scratch been performed since last update?
    • lfd346's avatar
      lfd346
      Thanks for replying, nut for whatever reason my app said my system was disconnected. I was accessing from my mobile , but when i got home everthing was fine. reloaded my app and seems to be working? Thanks
      • FURRYe38's avatar
        Please give feedback to the question presented...maybe something going on with app as well.
