SohCho
May 24, 2020Aspirant
ORBI RBR50
Hi All, need some help here. I am trying to split the 2.4Ghz and 5Ghz channels.
I telnet into the router and successfully am able to do this. After the router reboots I can see the 5GHz channel. But about 5 minutes later it quietly disappears and reverts to just the one SSID. Any help would be great. I'm surprised Netgear refuses to address this issue and insists on only having on SSID on their ORBI router.
Thanks
There are some really long posts about splitting the SSID's. Buried in them (somewhere) are discussions about how to make the change "persist". Good luck finding the right one.
If it's not too personal, would you share the reason for wanting to do this?
- SohChoAspirantWhen I use a device in a specific room in a corner of my house in the basement of always connect using 2.4GHz with really weak signal and sometimes even dropping. I don't know why it won't switch over to the 5GHz band. If I separate these then I can atleast explicitly use the 5GHz channel.
- CrimpOnGuru - Experienced UserConventional thinking is the 5G signals do not propogate as far as 2.4G signals, so trying to connect at 5G when 2.4G is weak is doomed.
One easy test is to use a WiFi signal Analyzer app on Windows or Android to look at the signal strength of the Orbi channels. The Orbi SSID should appear two times for each Orbi unit. (once on a 2.4G channel and once on a 5G channel). It might be worth a few minutes to confirm that the assumption of 5G being "better" is correct.
Is it only one device that does this? Do other devices connect automatically at 5G?
