APS007
Jun 07, 2020Aspirant
ORBI RBR50
I have just installed and all seems to be working, except by devices say No Internet Access even though there is and it is working. Anybody else seen this, and how do I get to make the devices report accurately?
Thanks
Andy
Is the Orbi system operating in Router or AP mode?What devices do you have connected?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-SpeedTry enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).- APS007Aspirant
Hi
Lots of questions, I’ll do my best.
The firmware is V2.5.1.16
The Internet service is via Vodafone and I have plugged the Orbi into a spare port on the Vodafone router as per the Netgear instructions. The Orbi has an IP address of 192.168.1.12. The devices connected to the Orbi include Windows laptops, IMacs, iPhones, iPads, a Nest hub, Android tablet and several Kindles. All get 10.0.0.x addresses.
They all connect but the PC reports no internet connection but it works. The Android device shows half of the Wi-Fi symbol with a ! mark and reports no internet in the settings, but works.
If I plug in a device to either Orbi on a cable no problem..
I have got good reception around the cottage so no worries there.
Please advise
Thanks
Andy
- APS007Aspirant
Hi, Just found how to switch to AP mode, problem solved..
Thanks for the hint.
Andy
