mrsgarfield's avatar
mrsgarfield
Orbi RBR50
Can I access Orbi without using the App? If yes, how can I access it via Safari. Also, can I find out what time a device start using my wifi?
Thanks.
    • mrsgarfield's avatar
      mrsgarfield
      Thanks. I am in. How can I find out if a device has accessed into my guest wifi?
      Earlier today, there is an unknown device "Google Chrome" showed up on my Guest Wifi. I freaked out and blocked it. Then I reset the Guest wifi name and password. Is it too late to see if the Google Chrome device was accessed my wifi?
      Thanks for your advice.
