mw1999's avatar
mw1999
Orbi RBR50r2 - firmware V2.3.5.30 - slow download speeds
I have 500 Mbps service from my ISP.  Checking my download speed prior to connecting to the Orbi, I get very close to 500 Mbps.  After connecting to the orbi and checking the download speed -- it is about 80 Mbps.  This is with a wired connection.
I have tried different cables, different ports, etc -- all with the same result.
Any help you can give me would be greatly appreciated.  TIA
  • Please mark your thread as solved so others will know.
    Enjoy.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    Armor, Circle,
    Try a different wired PC to compare.
    • mw1999's avatar
      mw1999
      I have no modem from the isp -- the line comes in direct.  I can connect to that line to a computer  and get speeds of 500+Mbps.  Running a speed test from the orbi app, the speeds are also very high.  However a device connected directly to a port off the orbi and the speeds decrease by 50%-80%.
      I have not reset and setup from scratch since the firmware update -- I will try that.
      I have tried different computers connected directly to the orbi -- the best I get is 50% reduction in speed.
      Neither circle, nor armor are enabled.
      • FURRYe38's avatar
        Ok, let us know what you see after the reset.
