rhultman22
Apr 29, 2024Aspirant
Orbi RBR50/RBS50 old router name with wired connection
AC3000 Tri-band WiFi Router Model RBR50 with 1 RBS50 satellite Firmware version V2.7.4.24 Windows 11 laptop connecting A family member purchased this mesh network new and installed it as SSID "pla...
rhultman22
Thanks for the confirmation. I noticed that it seems to work OK, although it seems to take a long time to connect. I rebooted the laptop and the wired connection appeared to not be connecting. I unplugged it, then plugged it back in. It took almost a minute before it connected and showed up as 'platypus'. I can't recall if I did a factory reset or not before plugging it in. I backed up the configuration. I wonder if I should do a factory reset, then reload the configuration file?
Apr 29, 2024Guru - Experienced User
Try a reset then see if things work with out the back up config. If it does, then make a new back up file.
Also check into last released FW version as well:
- rhultman22Apr 29, 2024Aspirant
See attached screenshot. Logged into Orbi > Advanced > Firmware Update > Check, it says it's at V2.7.4.24 and "No new firmware version available". I saw another post from you from 2023 describing Netgear's behavior regarding autoupdate. I conclude that you suggest I download and install the newest 2.7.5.4 version?
- FURRYe38Apr 29, 2024Guru - Experienced User
Ya, AU has been problematic for Orbi AC series. Since the AC series is EoL, NG isn't auto updating anymore. Only if something security wise is needed, maybe however for the most part now, manual updating will be need at the users discretion. Can follow this process I posted in a PDF file: https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2359585/highlight/true#M53030
- CrimpOnApr 29, 2024Guru - Experienced User
Please check the Advanced Tab, LAN Setup page and see what Name has been assigned to the router.
(on my router, the name is on the FAR right side of the page)
