sinfulangle
Apr 04, 2025Aspirant
Orbi RBR50v2/RBS50v2 Slow Speeds on Gigabit Internet
Hi there, I currently own the Orbi Router RBR50v2 & Orbi Satellite RBS50v2 and currently have a Gigabit internet (A HFC connection). On Ethernet, I get speeds of 940 Mbps (Download) and on Wi...
CrimpOn
Apr 04, 2025Guru - Experienced User
What WiFi system does your friend have?
What device is being used to measure speed when connected using WiFi?
Which WiFi band is this device connected to? (2.4G or 5G) The web Attached Devices page, the Orbi 'app' Device Manager, or (sometimes) the phone's WiFi settings will display the frequency band and sometimes the WiFi Link Rate.
sinfulangle
Exactly the same as me.
- speedtest.net
- fast.com
5GHz
- CrimpOnApr 05, 2025Guru - Experienced User
I agree. 150Mbps is much lower than one would expect. It is either (a) the device (phone? laptop? tablet?) or a lot of interference from nearby WiFi systems.
If other WiFi devices show the same level of performance, it might be time to survey the 5G WiFi interference. There are tools that can show how many systems are nearby and what their strength is. The Orbi 'app' has a WiFi Analytics function which show the number of WiFi systems on each channel. Unfortunately, in many countries there are not many choices for users to pick from.
- sinfulangleApr 05, 2025Aspirant
The phone/laptop reports the same speeds so it's not them.
Interference from nearby WiFi systems could be an issue, however, remember that I get the same Wi-Fi speeds if I literally stand right next to the router.There is no WiFi analytics on iOS unfortunately:
https://community.netgear.com/t5/Orbi-App/Orbi-RBK50V2-wifi-analytics/m-p/2353998- CrimpOnApr 05, 2025Guru - Experienced User
If other WiFi systems are impacting the 5G spectrum, then distance from the router is not relevant Every WiFi device looks for an opportunity to use the available frequency. If too many WiFi devices are active, there may not be much spectrum left.
We need someone experienced with "Apple Things" to provide a direction toward more information.
