orbiuser1975's avatar
orbiuser1975
Apprentice
Dec 29, 2020
Orbi RBR750 Backhaul Connections Reported Incorrectly
Just installed a RBR750 router/satellite system. Both the router and satellite have firmware V3.2.16.22_1.4.9. The satellite backhaul connection is via CAT5e through a switch (not direct).  Couple of questions:
1. I have noticed from the app that all devices connecting to the satellite are showing up as "wired" connections on the router. Will this ever be addressed to show appropriately as "wireless" connections on under the satellite?
2. The guest network option is enabled and guest network connection through the satellite don't show up guest network connections, but rather "wired" connections through the router. Will the incorrect reporting for guest connected devices be addressed? This one just stumps me, as I can see the guest connected devices are on a different subnet, so should be easily determined as "guest" even though they come through the wired backhaul.
