bmxsteve
Dec 30, 2020Aspirant
Orbi RBR750 showing multiple SSIDs
Hello, I recently upgraded my old Orbi system to a RBR750. As I was going through the initial setup, I used the previous wifi name/password so I did not have to update all my devices. Everything i...
CrimpOn
Dec 30, 2020Guru - Experienced User
bmxsteve wrote:Thanks for your advice on how I can remove the default SSID.
Has the router been powered off and back on?
p.s. Netgear set up a community forum specifically for the "AX" products. People who own the 750 Orbi may have had similar experiences and be able to share their solutions if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- bmxsteveDec 30, 2020AspirantYes, it has been rebooted several times. Any other thoughts or ideas?
Thanks for the link for the other forum, I will post there in the future.
