TAC57's avatar
TAC57
Orbi RBR750 Speed test vs Asus Mesh?
Might anyone give me any insight on the following?  I was planning on updating my home network with the Orbi RBR750 WiFi 6 system.  My existing system is two Asus routers setup in an AiMesh.  I got the ORbi RBR750 today and set it up. The two setups are pretty close to the same as far as the routers locations and the satellites are right next to each other.  So I'm thinking distance and walls really should be a problem.  I'm connecting to the satellite of both system to run the following Ookla tests (www.speedtest.net).
Orbi Speed TestAsus Speed Test
