plagana57's avatar
plagana57
Orbi RBR750 Wifi 6 Much Slower WIFI than wired internet? 500/302 vs. 945/852. Is this normal?
Set up in my home office.
I have a large home, 5,000 Sq Feet 2 floors
Orbi WIFI 6 Mesh Model RBR750
Firmware V3.2.16.6
Fios 1 Gig fiber internet plugged directly into Orbi WAN port with CAT 6.
Speed test says Upload 945 Download 852 for wired internet
I stand in front of Orbi and do a speed test with my I Phone for wifi and get 500/302.
I hardwired a satellite 75 feet away in opposite part of the house and get 463/410  for wifi test. 20 or 30 feet away from the router or satellite and add a couple walls wifi drops by 50 - 75 %.
Is this normal?
My front porch shows wifi as 11/2 so I have to use an extender, Netgear EX2700, for my RING doorbell.
  • Is your iphone AX supporting?
    Most AC supporting devices max out at 400-500Mpbs on 5ghz AC wireless.
    • plagana57's avatar
      plagana57
      THank you so much for your comment.
      You are correct my IPhone does not support AX, but my point is i feel my WIFI numbers should not drop to under 75/75 at the other end of my house when I have the satellite hardwired to the router and it is postioned directly under the bedroom floor in the basement. Also my dining room 43/22, front porch 11/2,??? is this normal or do I need to work at it a little to get it to increase? Maybe buy another satellite?
      • FURRYe38's avatar
        Guru
        The distance will cause speeds to drop.
        Did you disable the wifi radio on the phone first, then move closer to the RBS, then re-enable the phones wifi radio so it will connect to the RBS? Sometimes phones will keep the connection to the farther signal untill it's force to disconnect then re-connect to find something closer.
        Be sure your using good quality LAN cable between the CBR and RBS. CAT6 is recommended.
