Voodoo_ca
Jul 23, 2018Aspirant
Orbi RBR/RBS50 Firmware Updates
I have the WiFi system with a router and satellite. Everything has been working fine until yesterday. I saw there was an update to the v16 firmware so I let it update. I have a couple issues now. ...
Jul 23, 2018Guru - Experienced User
Try a full factory reset on the router and satellite. Setup the router from scratch. Don't add the satellite just yet. Test the routers wifi. If it seems good, then re-add the satellite.
