Voodoo_ca
Jul 23, 2018Aspirant
Orbi RBR/RBS50 Firmware Updates
I have the WiFi system with a router and satellite. Everything has been working fine until yesterday. I saw there was an update to the v16 firmware so I let it update. I have a couple issues now. ...
Sep 24, 2018Guru - Experienced User
Let us know if the suggestions have helped you.
The strangest is the connection via WiFi from the orbi to my MacBook. It shows connected to WiFi, and it tries to load some pages - but it is SLOW. So bad sometimes that it disconnects. It was fine before the firmware upgrade and a hardware into the orbi to the computer works great. Also, there is an issue where the firmware on the satellite has a NA after it and keeps showing that there is an update.
Is the previous firmware v10?
Can I just do a manual install and downgrade?
Anyone else have these issues?
Chad
radamchak
Sep 24, 2018Guide
.16 is supposed to be installed manually.. not automatically.. then do a factory reset after install. Yeah, i know, but hat's what they said.
