Royalh13
Nov 30, 2017Star
Orbi RB(R/S)50 Not Auto Updating to Firmware v2.0.0.76
It appears that there's a firmware hotfix available here: https://kb.netgear.com/000049562/RBR50-RBS50-Firmware-Version-2-0-0-76-Hot-Fix However when I log in to my Orbi using the Android App and...
- Nov 30, 2017
2.0.0.76 is a Beta release, the Orbi only auto-updates to official releases. You can, however, download the firmware from the page whose URL you have quoted, and manually update your Orbi. It's easy to do, just remember to update the satellite unit first. Usually, the release notes for a firmware release tell you how to manually update your Orbi. The release notes are usually included in the .zip firmware image archives. In the case of 2.0.0.76, release notes are in the .zip archives, and they describe how to flash the firmware onto your Orbi units in detail.
I've manually flashed to 2.0.0.76 Beta, and my Orbi is doing great using it.
tagteam
Nov 30, 2017Virtuoso
Royalh13 wrote:
...Firstly, why doesn't the 2.0.0.76 firmware show up when I check and secondly, why didn't the Orbi automatically update itself?
It's *beta* firmware; they only push release versions.
- Bing-StrollerDec 04, 2017Luminary
Is there any update on a stable release ?
Thanks
- Royalh13Dec 04, 2017StarIt is also marked as a "HotFix" so I'm not sure that it should be called a Beta?
Or if it's a Beta, then should it really be marked as a HotFix, which may mislead people into thinking that it's a critical fix.
I would think that "Beta Security Patch" would be a better description.
Also, it's been over a month now - how long does NetGear normally take to go from Beta to Prod? - DarrenMDec 05, 2017Sr. NETGEAR Moderator
Firmware 2.1 was just released
https://community.netgear.com/t5/Orbi/Announcing-availability-of-OrbiOS-2-1/m-p/1447612#M16893
DarrenM
- Royalh13Dec 05, 2017StarThanks!
Looks like I'll have to do the update manually again though, since my Orbi still says no newer firmware available, even after I hit the Check button...
Edit - just saw the note on the update page saying that auto-update will be available "soon"...
