Royalh13
Nov 30, 2017Star
Orbi RB(R/S)50 Not Auto Updating to Firmware v2.0.0.76
It appears that there's a firmware hotfix available here: https://kb.netgear.com/000049562/RBR50-RBS50-Firmware-Version-2-0-0-76-Hot-Fix However when I log in to my Orbi using the Android App and...
- Nov 30, 2017
2.0.0.76 is a Beta release, the Orbi only auto-updates to official releases. You can, however, download the firmware from the page whose URL you have quoted, and manually update your Orbi. It's easy to do, just remember to update the satellite unit first. Usually, the release notes for a firmware release tell you how to manually update your Orbi. The release notes are usually included in the .zip firmware image archives. In the case of 2.0.0.76, release notes are in the .zip archives, and they describe how to flash the firmware onto your Orbi units in detail.
I've manually flashed to 2.0.0.76 Beta, and my Orbi is doing great using it.
Bing-Stroller
Dec 04, 2017Luminary
Is there any update on a stable release ?
Thanks
DarrenM
Dec 05, 2017Sr. NETGEAR Moderator
Firmware 2.1 was just released
https://community.netgear.com/t5/Orbi/Announcing-availability-of-OrbiOS-2-1/m-p/1447612#M16893
DarrenM
- Royalh13Dec 05, 2017StarThanks!
Looks like I'll have to do the update manually again though, since my Orbi still says no newer firmware available, even after I hit the Check button...
Edit - just saw the note on the update page saying that auto-update will be available "soon"...- RogerSCDec 05, 2017Virtuoso
Yes, just did the manual update, and looks good to me *smile*.
