EFG502SGC
Jun 03, 2018Follower
ORBI RBS20 compatible with an RBK43 system?
Is the RBS20 compatible with an RBK43 system? Where the RBK43 consists of 1 RBR40 and 2 RBS40 devices.
Reason for asking is that I would like to add existing WiFi to ethernet devices, and I’d prefer to keep everything on the same SSID.
Would the addition of 1 or 2 RBS20 satellites to existing RBK43 system have a detrimental influence of the RBK43 system? Or, would it improve RBK43 system, while at the same time add extra ethernet ports?
I believe the RBS20 satellite’s have 2 ethernet ports per device, which would suit the need perfectly.
Thanks, and best regards
1 Reply
Ther RBS20 units are all the same so they will work just fine. Others have posted having up to 6 satellites on there systems, however NG only recommends 3 or 4 I believe. Be sure the distance between the router and satellites are starting at 30feet minimum.
