Jazzik's avatar
Jazzik
Orbi RBS50 Backhaul, is it possible to confirm if my Satellites are using the ethernet backhaul?
When I look at connected devices, both satellites are displaying connected 5ghz, I would expect this to have changed to wired the same as the other devices.
  • If you wired your satellites with the router and you still see the connection type as 5 GHz then there must be something wrong with the cables or something else.
    Both the web GUI and the Orbi app should show you the satellites as wired if they are wired.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    What is the Mfr and model# of the ethernet switch in the configuration?
    • Jazzik's avatar
      Jazzik
      Router Firmware Version V2.3.5.30
      I'm actually connecting the router to a Meraki Switch, which then  goes into a Palo Alto VM300 firewall before reaching my ISP router.
      AP Mode as I have the VM300 firewall handling all of my security and routing.
      The satellite is just connected to a dumb NG switch, through a patch panel which runs to my downstairs
      • FURRYe38's avatar
        What is the Mfr and model# of the ethernet switch in the configuration? Reason for asking is that some switches can cause problems with Orbi satellites being connected via ethernet. Particularly managed or green ethernet featured switches.
        Best way to confirm the RBS is connected via ethernet is to check the status on the RBR connected devices web page. The RBS will either show wireless or wired.
