marcj75
Oct 05, 2018Aspirant
Orbi RBS50 Flashing White Continually
PLEASE HELP!!!!!
Invested a new Orbi RBR50 with RBS50 Satellite.
All setup correctly out of box but then firmware updates happended and it all went wrong.
Router has updated to v2.2.1.210 and i...
Leo117
Oct 05, 2018Tutor
- Bring your Orbi router and satellite near to your router and laptop.
- Now remove the ethernet from the orbi router.
- Plug in the power and wait 3-4 minutes.
- Press the reset button and hold it until you see Blinking amber.
- Now wait until your router is re-booted. It takes 5 minutes.
- In the mean time reset your satellite. Follow step 4.
- Now connect the ethernet cable from your host network to Orbi router's WAN port.
- Connect another ethernet cable from Orbi router to your laptop.
- On your laptop access www.orbilogin.com or http://192.168.1.1
- Now follow the instructions and complete the setup.
- On firmware upgrade page cancel the process.
- Download latest firmware Zip file and extract it on desktop.
- Download latest firmware here.
- Click Advanced > Administration > Firmware Update.
- Select Manual Update.
- Browse Firmware from desktop.
- Hit upgrade.
- You can do the same for Orbi satallite.
NOTE- You can always do the hard 30 seconds reset if it gives you the same problem.
