ASGILL
Jan 15, 2022Guide
Orbi RBS50 no internet
I have Orbi RBR50 with RBS50 satellite, from last few months I started loosing internet on any device that connected to satellite, so I have factory reset whole system, satellite was able to connect after that but loosing connection intermittently. System has latest firmware
Any advice, Is satellite faulty?
Or there is something I can try
Thanks in advance
Thanks in advance
So its only the 1 satellite loosing connection?
have you tried moving it around to see if its a location or interference issue?
How far from the router is it?
What are your interior walls made of and how many are between the router and the satellite?
- ASGILLGuide
10-15m, yes tried most of the solutions, incuding factory reset, Sat works for some time, devices connected to this particuar SAT show good signal strenth but no internet till I turn it off and devices can connect to RBR50, trouble is moving around bit further in house, RBR50 does not have range that far, hence this SAT
