Gregstar
Apr 22, 2020Tutor
ORBI RBS50 (RBK50) Firmware upgrade - MAC TFTP -New Purchase not working
NB my model number is not listed - but it seems closest to the one above I have purchsed this Orbi RBK50 Mesh Wifi System https://netgearstore.sg/collections/orbi-wifi-mesh-system/products/netgearor...
- Apr 22, 2020
First off please confirm the FW version seen on the RBR using a wire connected PC and web browser connected to 192.168.1.1.
You can directly update the RBS to v16 by using this process first on the RBS:
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minute. The PC will get a IP address from the satellite. it will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password. Use the satellites web page FW update feature to select the FW update file that was unpacked from the .zip file. Then factory reset and then re-sync the satellites to the RBR.
The RBR will need to be updated as well to v16 before you attempt to connect the RBS to the RBR. They need to be on the same version of FW.
Apr 22, 2020Guru - Experienced User
Yes.
Yes.
Gregstar
Apr 22, 2020Tutor
Firmware version of Router is V2.3.5.30.
Should I update this to the V2.5.1.16 first or find the old firmware to update the Satellite?
- FURRYe38Apr 22, 2020Guru - Experienced User
I would update the RBS first to v30. v30 should apply directly to the RBS using the wired PC connected to the RBS.
You can upate to v16 later on if you want to.
- GregstarApr 22, 2020Tutor
When I connect the satelite to a laptop, I do not get a "router" IP address assigned and the power LED flashes red permanently. Is this the red flash of death?
Eeeks. So pressing the back reset button for 15 seconds then release change the LED behavior. If you don't see green on the back LED, then the RBS is bad.
