Stallion69
Dec 02, 2020Tutor
ORBI RBS50 Satellite
One of my satelittes keeps pulsating white and will not stop. I disconnected it for a week because i was remodelling my office. I rehooked it up and it won't go online. I have both satelittes hook...
Stallion69
Dec 03, 2020Tutor
I am currently running Firmware V 2.7.0.70.
I have both satellites hardwired directly to the back of the RBR50 router. Ran fine for over two years. Now one RBS satellite will not connect.
I will try to swap them and see if that does anything.
Dec 03, 2020Guru - Experienced User
Please downgrade to v16:
I foudn that v2.6/.7 versions of FW cause problems when RBS are ethernet connected.
- vajimDec 03, 2020Master
...and?
- Stallion69Dec 03, 2020TutorI will try swapping them and let you know. Weird why I have to downgrade firmware. Isn’t the whole point of upgrading firmware is to make the product run better?
In this case you were probably better off to NOT upgrade. Many of the FW versions have been and continue to be NOT ready for prime time. Use at your own risk.
- FURRYe38Dec 03, 2020Guru - Experienced User
Upgrades are appart of the process. Just sometimes problems are introduced in newer updates. I let NG support know about the problems found in the recent version of FW.
Stallion69 wrote:
I will try swapping them and let you know. Weird why I have to downgrade firmware. Isn’t the whole point of upgrading firmware is to make the product run better?- vajimDec 03, 2020Master
what process would that be?...sometimes..??
