edavis949
Aug 28, 2026Aspirant
Orbi RBS50 showing offline wont connect to RBR50
Tried everything, factory resetting everything updating to latest firmware, syncing the satellite from the app, from the devices, through the ip. Below is what shows up on the satellite web porta...
Aug 29, 2026Guru - Experienced User
edavis949 wrote:Any advice on how to get the second satellite connected to the router would be greatly appreciated.
The web portal shows that both are connected. So this looks like it might be a bug in the app. Have you tried reinstalling the app?
HappyCat wrote:Does the web portal Attached Devices display any devices connected to Satellite-2?
This would be a useful way to confirm that it is working properly. If nothing is connected, then try disconnecting and reconnecting your phone wifi while in the same room as the satellite.
