edavis949
Aug 28, 2026Aspirant
Orbi RBS50 showing offline wont connect to RBR50
Tried everything, factory resetting everything updating to latest firmware, syncing the satellite from the app, from the devices, through the ip. Below is what shows up on the satellite web porta...
HappyCat
Aug 29, 2026Virtuoso
and.......... the solution appears. Nothing on 2.4G. Nothing on 5G. Because the backhaul is 'wired'. Now:
- I can drag an Ethernet cable down the hall, down the stairs, and connect my satellite to wired backhaul, or
- edavis949 can report how that satellite is connected to the router.
