Timo002's avatar
Timo002
Tutor
Nov 17, 2020
Orbi RBS50 wired backhaul but keeps using wireless
Hello,
I have read a lot on this issue on this forum. But nothing found for my issue yet.
I have connected the satellite with a ethernet cable through a router, but the backhaul between the Orbi's is wireless instead of wired.
My setup:
  • TP-Link Archer C1200 as router connected to the inernet, WiFi switched off.
  • Netgear Orbi RBR50 in AP mode connected to the TP-Link
  • Netgear Orbi RBS50 connected to the TP-Link
The satellite (RBS50) is connected to the RBR50, but its backhaul is wireless (5G).
As suggested on this forum:
  1. I disabled IGMP in the TP-Link router, but that has no success.
  2. I switched off Daisy Chain Topology, but no success.
What else can I do to get the wired backhaul up and running?
  • Ok, I managed it this way:
    Internet
    TP-Link ———RBS50
    RBR50
    Now the RBS50 uses the wired backhaul!
    Tnx!
  • plemans's avatar
    currently you're going
    tplink----->RBR50
    RBS50
    Try it going:
    tplink----Rbr50-----RBS50
    The satellite should connect to the orbi router prior to connecting to the tplink
