PascalV's avatar
PascalV
Follower
Mar 31, 2017
Orbi RBS50
Hello,
I have a question , i have at this time the orbi DUO pack Router and RBS50 .
I buy a other RBS50 but my question is , how it work .
the RBS50 need to be sync with the router ? or he can sync with another RBS50 ?
Router <=> RBS50 <=> RBS50 ( is this way possible ? )
or
RBS50 <=> router <=> RBS50
Kind regards
Pascal
  • Retired_Member's avatar
    Retired_Member
    RBS50's can only be sync'd with the router.
  • PascalV wrote:
    Hello,
    or
    Kind regards
    Pascal
    the orbi system is star topology so all sats must connect back to the orbi router , the orbi system is not mesh based so  cant do as you want
    see
