Cmp55498's avatar
Apr 02, 2017
Orbi RBS50
I have a desktop running Windows 10 at the far end of the house from a RBS50 satellite.  Unfortunately, while the signal remains strong, the internet disconnects a lot.  I will be working and it will drop 5-10 times in an hour.  I used to use the TP-Link TL-WDM3200 and it has a known issue with the driver in windows 10.  I am currently using the ASUS AC55 with the same issue.
    i dont understand , where is the orbi router in this setup , the sat being at the other end of the house means the orbi router should be in the middle right ? and you would be connecting to the orbi router and not the sat ? or is the orbi router in another house
  • Yes, the orbi router is in another building and the satellite is in the building with the computer having internet issues. Sorry for the confusion.
    • peteytesting's avatar
      peteytesting
      Hero
      then the answer is ether move the comp to the sat or closer to it or run ethernet from the sat to the comp
      or
      get a better wireless adapter in your comp
      something like asus pce-ac68
      • Cmp55498's avatar
        Cmp55498
        Tutor
        The intensity of the signal from the satellite is not bad.  I have 4 bars and remain connected to the network, but then it disconnects me from the internet.  I am losing internet, but not losing satellite connectivity.  I am not sure how moving closer to the satellite or getting a higher intensity wifi card would fix that.
