MrHottPocket
May 15, 2023Aspirant
orbi rbs50v2 ping spikes
I bought my orbi routers almost a year ago. They were perfectly fine until late October when my ping started to spike out of nowhere and this went on for a month. At first i thought it was spectrum but i have found out that it is not. February 24th came and the ping spikes started but now they have lasted almost 3 months. I have tried everything i can find to try to fix them but have found no solution. They are on the latest firmware available. I had previously bought a netgear wifi extender and tried using that instead of the satellite but the issue is still there. I am pretty sure that this is an issue with the router not the satellite. It has been 3 months since i have been able to enjoy gaming any help would be greatly appreciated.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.How are you testing pings?
Have you run ping tests with a wired PC connected to the ISP modem directly then with the RBR in line using pingplotter.com test app?
What devices are all connected to the system?
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?️Try disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter.One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System- MrHottPocketAspirant
Both the router and the satellite are both running v2.7.4.24 the Mfr is spectrum and the model number is ET2251.
Yes i am using a cat 6 lan cable going from my modem to router and from my satellite to my pc.
When my pc is connected directly to the isp modem or my orbi router i experience no problems its as soon as i connect to my satellite i experience the ping issues I also sued the netgear extender in place of the satellite and had the same issue so it is a router wireless issue.
the devices connected are
my pc
3 phones
oculus
thermostat
and 4 roku tvs
we have only 1 orbi router and 1 orbi satellite
home size is 1,457 square feet
i have the satellite placed in my room all the way on the other side of the house so i would probably say 55-70 feet away from the router and the satellite shows blue when connecting to the routeri did as you said and changed the 2.4 GHz channel from auto to channel 1 and i changed the 5 GHz channel from 48 to 44 and i tested it and still experience the issue
every neighbor around me has wifi so i would say 10 at least but when trying to connect to networks 3 are in range of my house
and yes everything that you listed is disabled
i disabled daisy chain a month ago and the ping spikes are not as bad as they used to be but it is still happening i re-enabled the daisy chain after i tested the new channels without it and the issue still persists
i also have MU-MIMO on and beamforming on
i factory reset it about 3 weeks ago, i updated the software 2 months ago and the issue still persists i might try factory resetting it again but still no matter what i do it will not work.- KevinLiTNETGEAR Moderator
Hello MrHottPocket ,
I understand that you have been recently experiencing ping spikes with your RBK50 on FW v2.7.4.24. The latest FW for your RBK50 Orbi Mesh system is FW v2.7.5.4. To resolve this issue please ensure that your RBK50 Orbi Mesh system is on the most current firmware. Testing network connection with your ISP is highly recommended.
Please navigate to the link below for the download file for your RBK50:
https://www.netgear.com/support/product/RBK50#downloadPlease let us know if you require further assistance!
Best
Kevin
Community Team
- five months, ping good.
- one month, ping bad
- three months, ping good
- three months, ping bad
It is tempting to ask, "what changed?"
The VR Headset and PC are connected to the satellite. Sorry to display ignorance: which is used for gaming? (both together?) How is the PC connected (wired? WiFi?)
Unacceptable latency is being reported how?
- By the gaming software?
- From a test run on the PC?
ping plotter and in game ping both show the same thing
the pc is the only thing that i know is directly connected to the satellite because its connected through ethernet
