rickcandle87
Jun 06, 2017Aspirant
Orbi Re-Installation
I had a lot of trouble getting the orbi and satellite set up initially. I now need to power down and relocate the satellite and disconnect the cable feed to the modem upstream of the router. Que...
DarrenM
Jun 12, 2017Sr. NETGEAR Moderator
Hello Rhoadesusa
You will need to factory reset by holding the reset button on the back for 10 seconds.
DarrenM
