Rickonharwood's avatar
Oct 21, 2018
ORBI relocate in home
I wish to move my ORBI satellite to a different room in my home. What is the proper procedure to follow to complete this smoothly?  Do I disconnect the power from the satellite and place it where I want and connect to power?  Are there other steps to follow?  Thank you.
  • Rickonharwood:
    I believe after re-establishing power to the satellite, you would need to press the SYNC button on first the satellite and then the router to get communications to the router back again.
  • FURRYe38's avatar
    If you have already synced the satellites and wan to move any one of them, all you need to do is to power OFF the satellite, unplug it from the wall out let and place it in it's new position. Plug in and turn on and thats all. No need to re-sync.
    FYI:
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
    https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
