dsharla
Nov 18, 2020Follower
ORBI Relocation
Can I relocate an ORBI RBK50 from a permanent home to a vacation home? Are there any issues I need to consider?
dsharla wrote:Can I relocate an ORBI RBK50 from a permanent home to a vacation home? Are there any issues I need to consider?
Yes, of course. There is a good chance that you can simply connect the router to the modem and it will work immediately.
If the vacation home has a totally different type of internet connection (such as PPoE), you may need to do a Factory Reset and configure the Orbi: https://www.youtube.com/watch?v=cMw4ePACgc4
Yes.
Placement, distance between RBR and RBS and ISP modem configuration:
Moddem only unit being perferred...
