CharAp
Jul 17, 2018Follower
Orbi restart issues
Looking at the Netgear Orbi as a mesh wifi solution. Very good reviews all over the place but I also saw the following at TechRadar (https://www.techradar.com/reviews/netgear-orbi):
Second, should ...
tsig
Jul 17, 2018Luminary
I have turned off breakers powering the satellites and routers together and separetly and have had a power outage. Everything behaves as expected once power is restored. Sorry if this bust anyone's bubble.
RocketSquirrel
Jul 21, 2018Luminary
We all have different setups and different problems. For example, I'm using wired backhaul, and guessing that makes recovery from power outages more problematic. I imagine the Orbis power up looking for wireless backhaul first.
My bubble is still intact. Now if someone replies their wired Orbi system restores perfectly after a power outage, POP!
- waynealightJul 21, 2018Apprentice
i have similiar issues and I also put both my orbis on ups backups. I can restart them fine if they are wireless but ethernet backhaul creates another issue. If i have to restart I will unplug ethernet backhaul, restart both systems and let them sync. then plug ethernet back in. Its the most efficient was I can do it. This only happens if I'm changing firmware or a major network change that requires me to unplug the router. The backup keeps everything up and running with no issues.
- cvoiseyJul 22, 2018Guide
I am experiencing the same right now. The problem is that I can't get signal to all parts, so it sounds like I have the exact same problems. Wired backhaul is horribly implemented.
- FURRYe38Jul 22, 2018Guru - Experienced User
How have you set up your system?
Is Daisy chain enabled when you have wired back haul connected?
Whats the distance between the router and satellites?
SqFt of your home?
I set up my friends system with 1 wired back haul satellite and it's still going:
See if this helps you any...
- Retired_MemberSep 29, 2018
We appear to have the same issue, After rebooting the router, we have to hard reset the satelites with a needle.
Looks like double IP numbers are issued and.or the DHCP is not well implemted...
any tips?
- FURRYe38Sep 29, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
any tips?
