steinmr's avatar
steinmr
Tutor
Apr 07, 2019
Orbi RKB53 global differences
Is there any difference between Orbi RBK53 sold in the US and in Europe? Any differences in supported bands, interference etc.? Or are they interchangable? Planning on buying in US and using in Norway.
  • Under Advanced Wireless Settings they have a drop down for Region Selection, but as far as I can tell there's no way to change it from North America so you only have the option of those bands. You can still pick any time zone, so at least your time zone will be correct.
  • CrimpOn's avatar
    CrimpOn
    There definitely are differences in radio frequency use between the US and other countries.  The US does not allow use of the 2.4G bands 12,13, 14 for example.  And, there are different restrictions on 5G frequencies.
    There are a whole bunch of parameters that have the word "region" in them.  Telnet into the Orbi and type "nvram show | grep region" (no quotes)
    I have absolutely no idea if they can be changed safely, or what to change them to.
    • steinmr's avatar
      steinmr
      Tutor
      Thank you so much for the help from both of you.
      It would seem then, that at the very best the hardware itself is identical, but the european/us settings might be locked in software. I guess Netgear are the only ones that can answer if that is actually the case. I worry that this kind of change might not be officially supported anyways.
      Is there any chance that Netgear employees answer questions here?
      • SW_'s avatar
        SW_
        Prodigy
        Unless it's region locked and it's hard-coded in HW chip, installing a new firmware version for EU region will allow Orbi to pick/set the right region.  It's just a profile of which channels to enable or disable for a given region.
    • michaelkenward's avatar
      michaelkenward
      Even if you have a US adapter that says 100-120 volts, there is a good chance that the label is not correct. It may be a legal thing, but some of those adapters are really dual-standard and can handle 240 volts.
      By coincidence, just before I saw this message, I plugged the 100-120 volts US adapter for my RBS50Y into 240 volts. No fizz bang. Just power. Working fine.
      I have done the same thing with other US adapters from Netgear. They all happily work on 240 volts.
      Why bother to have two product lines when you can simply stick on a label to be legal?
