Sunelectric
Sep 17, 2018Aspirant
Orbi router - unable to access web interface of DrayTek Vigor modem
I'm using an Orbi router (RBR50) connected to a DrayTek Vigor 130 modem. Is it possible to access the modem UI without having to connect directly to it? i.e. via the router.
The Vigor 130 modem...
Sunelectric
Sep 18, 2018Aspirant
Thank you for your reply.
The Orbi router is currently being used in Router (not AP) mode. My ISP is Plusnet (if that makes a difference).
Sep 18, 2018Guru - Experienced User
Need to try one of the 3 suggestion, since your ISP modem already has a built in router. Having two routers on the same line can cause problems. Contact your ISP about setting up the modem for use with an external router. One of the suggestions should work.
- SunelectricSep 19, 2018Aspirant
The DrayTek Vigor 130 is just a modem (not the modem-router supplied by the ISP).
- FURRYe38Sep 19, 2018Guru - Experienced User
Then you should be able to access the modems UI thru the Orbi router. The Orbi router would not be blocking it. Most modems I've worked with use 192.168.100.1 as there entry point. Anything else should work as well. Might contact the mfr of the modem and ask of there are any known issues with Orbi routers...
