Unverif1ed's avatar
Feb 22, 2022
Orbi Router Access Control Problems (With Pictures)
Two nights ago my antivirus service detected numerous attempts to access my router that were not recognized. As a protection, it did something to block internet access temporarily (I think). Because for the next several hours I was without internet. Any attempt to access the internet and I would get an error message from Netgear (picture 1).
Now this morning, I get the same issue. So I try to log into the router, but I get the same screen (pic 1). I repeat this on other PC's to the same end. Then I try my phone, and am able to connect by logging into the router through my browser (despite the app not working).
When I get into the router, I notice it says no devices (and no satilites) connected. I have two satilites, but today neither will connect. So I go to what seems to be the root problem, Access Control. I promptly receive error code 500, which I think means that the device cant find it's own page at the indexed location. (Picture 2).
Then I go to blocking schedule, which I remember setting to 3am to 4am (so that I will remember to get a little sleep). It is now set to all day every day (pic 3). Mind you, while none of our computers can connect to the router, my personal computer it the only one without general internet access. The other computers can get in just fine.
As a last check, I confirm that there are indeed no devices attached in the advanced screen under device list. It shows no devices and no satilites. (Pic 4).
I also take note that my firmware is v2.7.3.22. (As seen in pics 2-4).
No I apply some standard fixes. I turn it off and on again. I try to sync a satalite. I ensure it's not a problem with my PC's network adapter. I power cycle my PC. Finally I do the dreaded task of doing an erase (factory reset) on my orbi. After it is set up again, I go to log in on my PC, and I get the same page. I log in successfully on my phone, but access control says the same thing. Error 500.
Do I just need to get a new Orbi at this point?
    • plemans's avatar
      And the schedule/access control survived the factory reset?
      did you have to go through the whole setup again?
      • Unverif1ed's avatar
        Unverif1ed
        Tutor
        It doesn't make sense. I would have thought that the reset would purge any screwed up settings. But yes, I resetup my wifi so my mom could use zoom. And she has access now, but my PC is still blocked, and trying to get to the access control page in the router settings is still impossible. It's as if the router itself cant find the access control page, but it has somehow saved that my PC needs to be blocked (along with my dad's phone, both satilites, and my brother's PS4). But dad's laptop, mom's PC, and all of our other phones remain unaffected.
