silvinnio's avatar
silvinnio
Orbi router cannot be found after factory reset
Few days ago I have upgraded  my ORbi RBK sistem to the latest firmware. The system worked OK but in the device list was only 2 devices from 10. After that I have done factory reset of the router and now  I cannot connect to the router again. I have  a white pulsing LED. I have tried factory reset many times with paperclip pressed on hte reset buton until amber LED was flashing and still no success.
Looks like the configuration is missing.
When I switch ON the power, the LED above power connection is green.
I have tried also manual IP  192.168.1.10  on the PC and still nothing.
There is no any wi-fi network  broadcasting.
  • michaelkenward's avatar
    michaelkenward
    It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    Where did 192.168.1.10 come from? Do you mean 192.168.1.1?
    After playing around with things, be sure to restart your network in this sequence:
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it connect.
    • Turn on computers and rest of network.
    • silvinnio's avatar
      silvinnio
      I am using orbi router rbk50 as modem with PPoE connection. When router is on there is no wifi network broadcast. Also if I connect by wire with my PC, it is not getting automatic IP so I have to setup manual IP as 192.168.1.10 on PC ethernet connection and router IP should be as 192.168.1.1.
      Still no connection.
      Already done all as suggested.
      Is there any way to force IP or to change the firmware? I know that can be used telnet connection but only if there is telnet activated.
        michaelkenward
        The RBK50 is a router/satellite (RBR50/RBS50) combination.
        It has to get the Internet from something. A modem, optical termination, something else.
        What have you got plugged into the yellow (Internet) port on the RBR50?
